КОЛЯ_RACE FAN.zp.ua Опубликовано 9 июня, 2006 Жалоба Опубликовано 9 июня, 2006 ...Биг Блок,1200-1400 л.с.,Квотер-7,2....This is an insanely EXTREMELY FAST AND NICE 1967 Camaro RS SS!!! 1200-1400 on a 250 squeeze HP capable to make even more power!!!! WARNING! THIS CAR IS NOT FOR THE TAME OF HEART! This car is very versatile to go show, race, or street! It would be top dog in all classes! This car is in excellent condition! It comes with a clean and clear 1967 title! The paint is a candy cobalt blue with a black stripe. Where to start.....This car has run 6 flat in the eighth without NOS and very little second gear. The car has potential to go low 8's/high 7's with the squeeze on single stage. The car is designed for a fogger and two stages of nitrous. The body has the fiberglass harwood hood and trunk lid with easy does hold downs. It has stretched rear quarters that maintain the factory lines. It has plexi glass windows in the front and rear that the seams are hidden under factory moldings. The side windows are glass and roll up and down. Has all original emblems, bumpers, headlight beazles, and taillights. Also have the rear reverse lights that come with. The holes are drilled for the back bumper so you can put it back on. Also comes with an extra bumper for the rear. Everything works on the car! The interior is completely fabricated in aluminum. The aluminum is all ball milled for integrity and strength. It has all auto meter pro gauges that include tach with shift light and MSD control pills, Speedo, 2 fuel gauges (1 for nitrous and 1 for fuel), and oil and water temp. The gauges are liquid filled so as not to shake. Painless wiring control boxes that control nitrous, water pump, electric fan, 2 fuel pumps, arming switches for the nitrous, ignition and starter. It has Jaz seats in it with 5 point racing harnesses. It has a hurst shifter with trans brake on the top. It has a quick release steering wheel with nitrous and line lock drilled into the wheel. It has a professionally installed 14 point roll cage that includes quick release net. It has on/off switches for the lights and on/off switches to engage the alternator. The car does have hideaway headlights. The tires are in good condition and are 29x33x15 with Mickey Thompson drag slicks. 3.5x15 on weld drag lights on the fronts. The rears have screw-in studs. All safety features of this car to include cage, motor, transmission, underbody, suspension are NHRA and IHRA certified parts for 7.50 quarter miles. The motor has the following features: It's a Keith Black Big Block with aluminum heads Callies Billet Crank Billet splayed main caps Billet Rods JE Pistons For Nitrous Lowered Top Land Complete Solid Roller valve train Solid roller cam at almost 800 lift Roller Lifters Roller Rockers Guide Girdles Polly locks Ported and polished heads that have been hogged out Intake manifold has been hogged and polished to match to maximize flow 1150 CFM Dominator Carburetor MSD Ignition to include 7al box 2 Step rev limitator Nitrous Control Box to control up to 3 stages of nitrous CSI Billet Water Pump CSI Water net Billet timing cover specially machined for this motor to prevent cam walk 8 quart morso pan, windage tray and trapdoor oiling system All BG fuel system to include pumps regulators, filters, and all hardlines from BG. All the brackets on the motor were custom made Front motor plate is custom made up under the motor and bolts to the front of the block and to the frame to prevent motor twist Single stage of nitrous with 250 jets 4 quart radiator Oversized headers and exhaust for street application for pro street NHRA certified TCI Transmission 2 speed power glide with a reverse valve body Nitrous 5000 stall converter and trans brake Transmission cooler Shortened drive shaft Mark Williams 12 bolt rear end to include mini spool axels, eliminator seat clips, shortened and narrowed by Mark Williams and all internals to include mini spool, axels and seat clips and 4:56 gears Ladder bar suspension with Konie coilovers professionally installed and shortened and narrowed Wilwood disc brakes on all 4 corners Proportioning valves Underbody relocated master cylinder Top and bottom of motor are bullet proof and built to handle heavy doses of nitrous REDLINE
КОЛЯ_RACE FAN.zp.ua Опубликовано 9 июня, 2006 Автор Жалоба Опубликовано 9 июня, 2006 Custom leather racing bucket seats Custom door panels with original factory style pattern Prowler purple paint. Truly flawless Original style rally stripes painted in flip flop Steel hinged cowl hood Most unique feature of car in under side of frame All welds ground down on frame Lots of black powder coating of frame All suspension parts coated or painted Under side of floor pans and wheel wells painted Four link system with diagonal bar 35 spline axles Ford 9” rear 456 gears 4500 stall converter 10” 800 HP 540 cubic inch shafiroff motor, 5 running hours 400 transmission Merlin block, Pro 1 Heads Dyno sheet, cam card REDLINE
КОЛЯ_RACE FAN.zp.ua Опубликовано 9 июня, 2006 Автор Жалоба Опубликовано 9 июня, 2006 427 Big Block Bored .30 Over 671 Blower w/Turbo Water Injection System Dual Carter 750 Carburetors Steel Crank/TRW Pistons Rectangular Port Heads/Cross Drilled & Chambered Single Angled Valve Job 2% Over Driven for More Boost Howe Radiator w/16” Electric Fan Transmission Cooler Jet Hot Headers All New Lines/Fittings/Hoses/Clamps EVERYTHING NEW Very Detailed and Nice Under The Hood Under Carriage: Turbo 400 Transmission (special built) Shift Kit/2200 Stall BDS Pressure Diversion Valve Ford 9” Rear End w/355 Gears (very streetable) Morrison 1810 Am/Pro Coilovers Morrison Frame Rails Drive Shaft Loop Flow Master 50 Series Mufflers Steel Rear Floor 4-Link Chassis Sandblasted & Powder Coated A-Arms New Bushings/Ball Joints/U-Joints Chrome Oil Pan 4-Wheel Disc Brakes Very Nice Underneath REDLINE
КОЛЯ_RACE FAN.zp.ua Опубликовано 9 июня, 2006 Автор Жалоба Опубликовано 9 июня, 2006 А вот Нитро пробуют!!! REDLINE
Андрюха_2108 Опубликовано 9 июня, 2006 Жалоба Опубликовано 9 июня, 2006 Пистоцьц.... Я тащусь от таких машин. Ех...почему наш автопром не имеет таких экземпляров?
Andrey120 Опубликовано 9 июня, 2006 Жалоба Опубликовано 9 июня, 2006 Эти кисы с какова горада?Мыроновка
DEN Опубликовано 9 июня, 2006 Жалоба Опубликовано 9 июня, 2006 Эти кисы с какова горада?думаю с юнайтед стат оф таки амэрика DRIVE2 Chevrolet Lacetti WTCC Toyota Highlander ♫ SQ Music
Andrey120 Опубликовано 9 июня, 2006 Жалоба Опубликовано 9 июня, 2006 думаю с юнайтед стат оф таки амэрика а дє цє?
Aquagen Опубликовано 9 июня, 2006 Жалоба Опубликовано 9 июня, 2006 думаю с юнайтед стат оф таки амэрика пендосики едут на другбитво?
